show cdp ports
show cdp ports {port_list} {configuration | detail}
Description
Displays information about neighbors in ports.
Syntax Description
port_list Specifies the port list, separated by a comma.
configuration CDP local port configuration.
detail Detailed information.
Default
N/A.
Usage Guidelines
Use this command to display CDP port information.
The following command displays neighbor port information on the CDP feature:
# show cdp ports
Neighbor Information--------------------
Port  Device-Id            Hold time  Remote CDP  Port ID
                                      Version
1     Eni-Extreme-switch-sw> 149        Version-1   Slot:  1, Port:  1
2     00:04:96:8B:9D:B0    160        Version-2   Slot:  1, Port:  2
7     00:04:96:8B:C1:ED    138        Version-2   Slot:  1, Port:  7
">" indicates that the value was truncated to the column size in the output.
The following example displays the COS extended neighbor port information on the CDP feature:
Local Port Information
Port     Trust       Cos   VoIP VLAN                        VoIP VLAN
                                                            Advertise
1        Trusted     0     Default                          Solicited
2        Trusted     0     Default                          Unsolicited
The following example shows detailed information for port 10:
# show cdp port 10 detail
Device ID               : switch model
Port ID (outgoing port) : Slot:  1, Port: 10
Advertisement Version   : 2
Platform                : model name
Interface               : 10
Holdtime                : 162
Version                 :
ExtremeXOS version 22.4.0.5 xos_22.4 by kosharma
     on Fri Jul 14 12:28:36 IST 2017
Native VLAN             : 1
Duplex                  : Full
Trust                   : Trusted
SysName                 : switch model
This command was first available in ExtremeXOS 15.4.
The output of this command was updated in ExtremeXOS 21.1.
The detailoption was added and the output of this command was updated in ExtremeXOS 22.5.
Platform Availability
